[GRASSLIST:4389] v.extract type=site fails
Maciek Sieczka
werchowyna at pf.pl
Tue Sep 21 20:09:19 EDT 2004
hi there!
I want to extract site-features from my vector file in Grass 5.3 but when
I'm doing:
v.extract input=rzezba output=rzezba_sites type=site new=0 list=0-1000
I'm getting :
Failed to attach an attribute (category 219) to a line.
and so on in respect to all the site-features
a result is a vector file with points labelled 1-20 instead of their actual
cats
is there any workaround?
the line-feature extraction is working fine however
Maciek
process in detail:
GRASS:~ > v.extract input=rzezba output=rzezba_sites type=site new=0
list=0-1000
Loading vector information.
Result of cats initialisation is 0
Making category file
V.SUPPORT:
Selected information from vector header
Organization: rzezba zlewni
Map Name:
Source Date:
Orig. Scale: 10000
Snapping threshold 0.00
Snapping threshold was saved in the vector header.
No snapping will be done.
Reading Vector file 100%
Building areas 100%
Building islands (no islands present)
Attaching labels
Failed to attach an attribute (category 286) to a line.
Failed to attach an attribute (category 316) to a line.
Failed to attach an attribute (category 213) to a line.
Failed to attach an attribute (category 226) to a line.
Failed to attach an attribute (category 222) to a line.
Failed to attach an attribute (category 207) to a line.
Failed to attach an attribute (category 199) to a line.
Failed to attach an attribute (category 302) to a line.
Failed to attach an attribute (category 212) to a line.
Failed to attach an attribute (category 208) to a line.
Failed to attach an attribute (category 178) to a line.
Failed to attach an attribute (category 223) to a line.
Failed to attach an attribute (category 204) to a line.
Failed to attach an attribute (category 198) to a line.
Failed to attach an attribute (category 277) to a line.
Failed to attach an attribute (category 284) to a line.
Failed to attach an attribute (category 239) to a line.
Failed to attach an attribute (category 193) to a line.
Failed to attach an attribute (category 216) to a line.
Failed to attach an attribute (category 210) to a line.
Failed to attach an attribute (category 215) to a line.
Failed to attach an attribute (category 296) to a line.
Failed to attach an attribute (category 184) to a line.
Number of lines: 25
Number of nodes: 25
Number of areas: 0
Number of isles: 0
Number of atts : 0
Number of unattached atts : 25
Snapped lines : 0
Extracted vector file <rzezba_sites> has been created in the 'dig' directory
[Raster MASK present]
GRASS:~ >
