[GRASSLIST:4391] Re: weird lines
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Wed Sep 22 02:16:27 EDT 2004
Ahmet,
this probably depends on the type of map that you have. You might want
to reset your color table if it is a DEM. Or you might check the type
of data you are patching. They might not be seamless in real life.
Adjacent maps often do not match up exactly, even from the same source.
If you still have a problem, tell us what kind of data you are
patching.
Good luck,
Ian
On Sep 21, 2004, at 10:57 PM, temiz wrote:
> hello
> when I use r.patch, the result map has a thin line at the joined edge
> of maps.
> how can I eliminate these lines.
> regards
> Ahmet Temiz
> ______________________________________
> Inflex - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the
> sender's own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
