[GRASSLIST:4419] Re: v.to.sites error
    Maciek Sieczka
    werchowyna at pf.pl
    Mon Sep 27 18:08:44 EDT 2004
> > It seems that v.to.sites fails to translate some points near the nodes.
> > Unclosed line's endings are not translated either.
> > This error does not depend on dmax.
> > DEVELOPERS! Should I give a bug report?
> > Maciek
> > P.S.
> > I wonder if v.surf.rst uses a smililar way to translate the input vector
> > lines to points thus commit the same error?
Radim wrote:
> Similar maybe, but not the same. Are you sure, that those lines have a
> category?
yes I'm sure
digitized and labelled in v.digit
each closed line has one node
the closed lines fail to convert to sites near that node
open lines have two nodes - one on each ending
open lines fail to convert to sites near the nodes on the line's endings
I worked the error around doing v.to.rast and then r.to.sites
Maciek
