[GRASSLIST:4421] Re: bug fixes for tcltkgrass for GRASS 5.3
Maciek Sieczka werchowyna at pf.pl
Tue Sep 28 05:50:05 EDT 2004
Michael,
thanks for fixing things
below I'm giving some comments and some more bugs I've found in the
tcltkgrass
> > 2. After choosing GIS->Map type conversions->Sites to vector I'm
> > getting: couldn't execute "s.to.vect -p": no such file or directory
> Fixed. Added option to enter or not enter metadata on new vector points
> created. To do this, s.to.vect now opens in an xterm where you can enter
> metadata if the -p flag is not checked.
"d.measure -s" also gives "couldn't execute (...)"
possible that more modules with a fixed "-" may behave the same if there are
any
> > IMO it uses a much different algorithm than s.surf.rst or v.surf.rst.
> > The only raster module utilizing regularized spline with tension is
> > r.resamp.rst (it'd be nice to have it in the tcltkgrass by the way).
how about about this module for r.resamp.rst some day?
> > 3. There is no entry for v.surf.rst in the vector menu - only in the
> > raster menu.
> Added module (already written by someone else) for v.surf.rst. Note that a
> couple of options (anisotrophy and another) are left out because the
> module is already as large as my screen and may not show up completely
> on lower resolution screens. I don't know why there is not an option for a
> vertical scroll-bar in the 5.3 menu module builder, but the modules are
> limited (practically) to the vertical screen resolution.
in general this a pain
even if working in 1024x768 (which is not low I think) still some of the
menus are not visible in full extent
BTW it also considers the NVIZ (I put a bug report on this)
It may be recognized as a not very important issue but as to me it is a
bug - since tcltkgrass is supposed to be GUI and NVIZ means for
visualization as well then they should be fully functional according to all
the graphics features they put on the screen for the user.
I understand that there are technical limitations in what can be done using
the tcltk but for as a user I only see a bug which should be fixed.
> > BTW - what is the r.surf.idw2 for anyway when it is slower, less
> > universal and gives identical results. Strange... Ask Grass developers?
> I don't know what the difference is either.
Can anybody say if there are any more diffrences between the r.surf.idw2
and *idw which justify both them being available?
and here a few more bugs:
1. r.surf.area should be r.surf.fractal propably because the output is:
Sorry, <out> is not a valid parameter
Sorry, <d> is not a valid parameter
Sorry, <n> is not a valid parameter
ERROR: Required parameter <input> not set:
 (Raster file for surface.).
Description:
 Surface area estimation for rasters.
Usage:
 r.surf.area input=name [vscale=value]
Parameters:
   input   Raster file for surface.
  vscale   Vertical scale
2. Something's wrong with the r.surf.gauss. When anything given for
"Gaussian distribution mean" got:
Usage:
 r.surf.gauss out=name [mean=value] [sigma=value]
Parameters:
    out   Name of the random surface to be produced
   mean   Distribution mean
          default: 0.0
  sigma   Standard deviation
          default: 1.0
3. If any "xyz" button pressed in the "d.3d" menu the result is as you can
see on the attached d3d_xyz.png. It's been the same since the first Grass
5.0 I've ever used .
4. "3d.views" doesn't work because there is no such thing in Grass 5.3 but
there is "3d.view.sh" which you propably mean.
5. After "OK" In the "Module font" I'm getting:
bad window path name ".s_proj"
    while executing
"winfo children $path"
    (procedure "children" line 3)
    invoked from within
"children $path"
    (procedure "setfont" line 3)
    invoked from within
"setfont .$module $module_font"
    ("foreach" body line 1)
    invoked from within
"foreach module $module_list {setfont .$module $module_font} "
    invoked from within
".main_menu.mb9.m.m2 invoke active"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke active]"
    (procedure "tk::MenuInvoke" line 47)
    invoked from within
"tk::MenuInvoke .main_menu.mb9.m.m2 1"
    (command bound to event)
Maciek
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040928/407f6ddb/d3d_xyz.png
