[GRASSLIST:6324] Re: INSTALLATION PROBLEM
Massimiliano Cannata massimiliano.cannata at supsi.ch
Mon Apr 4 04:42:19 EDT 2005
I check my pc and I found that I have all the missing library, maybe in
the wrong place????:
> [root at istgis g.region]# find / -name rtree.h
> /usr/include/pgsql/server/access/rtree.h
> /usr/local/src/postgresql-7.4.5/src/include/access/rtree.h
> /usr/local/src/grass-6.0.0/lib/vector/rtree/rtree.h
> /usr/local/src/grass-6.0.0/dist.i686-pc-linux-gnu/include/grass/rtree.h
> /usr/local/src/grass-6.0.0/dist.i686-pc-linux-gnu/include/rtree.h
> [root at istgis g.region]# find / -name dgl.h
> /usr/local/src/grass-6.0.0/lib/vector/dglib/dgl.h
> /usr/local/src/grass-6.0.0/dist.i686-pc-linux-gnu/include/grass/dgl.h
> /usr/local/src/grass-6.0.0/dist.i686-pc-linux-gnu/include/dgl.h
> [root at istgis g.region]# find / -name shapefil.h
> /usr/local/src/postgresql-7.4.5/contrib/postgis-0.9.0/loader/shapefil.h
> /usr/local/src/gdal-1.2.3/ogr/ogrsf_frmts/shape/shapefil.h
> /usr/local/src/grass-6.0.0/lib/external/shapelib/shapefil.h
> /usr/local/src/grass-6.0.0/dist.i686-pc-linux-gnu/include/grass/shapefil.h
> /usr/local/src/grass-6.0.0/dist.i686-pc-linux-gnu/include/shapefil.h
> /home/Mapserver_php/gdal-1.2.4/ogr/ogrsf_frmts/shape/shapefil.h
Hamish wrote:
>>Hi, can anyone help me?
>>I cannot get any response ar idea about what is going wrong......
>>Here is the compilation log and as you can see I get no errors....
>>GRASS GIS compilation log
>>Started compilation: Wed Mar 30 10:03:08 CEST 2005
>>Errors in:
>>Finished compilation: Wed Mar 30 10:10:09 CEST 2005
>>(In case of errors please change into the directory with error and run
>>'make')
>>It seems that I get error in reading region...
>>by using the same WIND file on my laptop (whare i successfully install
>>GRASS-6.0.0) and on the server it gives me always the same
>>error.......
>>GRASS 6.0.0 (test1):/usr/local/src/grass-6.0.0 > g.region -p
>>ERROR: default region is invalid
>>       line 11: <top: 1>
>>her ethe WIND file:
>>proj:       99
>>zone:       0
>>north:      177846.30208341
>>south:      56014.58333336
>>east:       744765.89285719
>>west:       647731.25000004
>>cols:       970
>>rows:       1218
>>e-w resol:  100.03571429
>>n-s resol:  100.02604167
>>top:        1
>>bottom:     0
>>cols3:      970
>>rows3:      1218
>>depths:     1
>>e-w resol3: 100.03571429
>>n-s resol3: 100.02604167
>>t-b resol:  1
>>What can I try to meke grass working?
>maybe a dumb question, but are you sure this isn't happening in
>GRASS 5.4? (g.version)
>GRASS 5.4 can not currently read GRASS 6 region (WIND) settings and
>gives you that error.
>Hamish
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)91 935 12 25
Fax +41 (0)91 935 12 09
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050404/6ea56352/attachment.html
