[GRASSLIST:6359] Re: convert vector to raster
Hamish
hamish_nospam at yahoo.com
Thu Apr 7 04:32:22 EDT 2005
> 1. assign a colortable to a vector layer, based on a given column of
> attributes (something like r.colors for rasters)
> 2. preserve the rasters colortable after v.to.rast in the resulting
> vector layer (having RGB codes stored in GRASSRGB column)
r.to.vect?
> Has anybody got an idea how to achieve this fairly easily so it could
> be used for a daily work? Or would it require new functionality in
> Grass?
You would have to write something that created a GRASSRGB column and
populated it with formatted output from the raster's colr/ file.
To do it in a shell script, you would probably have to use g.findfile,
g.tempfile, and some db code stolen from the v.in.garmin script as well
as the usual unix tools. Shouldn't be *too* bad.
Or do it properly in the C code for r.to.vect / v.to.rast if you can.
The other direction is even easier as you can pipe directly to r.colors.
Hamish
