[GRASSLIST:6372] Re: r.terraflow and r.water.outlet
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Fri Apr 8 11:23:04 EDT 2005
I really don't know about r.water.outlet but while r.whatershed generate
flow direction with a D4 or D8 algorithm while r.terraflow use a Dinf
algorithm (6 month ago the -s flag was not working, maybe now is fixed,
maybe not.... try to test....).
Hope it can help.
Maxi
Eric Hillmuth wrote:
> Has anyone had any luck using the results from r.terraflow in
> r.water.outlet? More specifically I want to use the output direction
> grid from r.terraflow for the drainage direction map input of
> r.water.outlet. The r.water.outlet documentation only refers to using
> a drainage direction map generated in r.watershed.
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)91 935 12 25
Fax +41 (0)91 935 12 09
