[GRASSLIST:6380] Re: Startup Error GRASS60
Markus Neteler
neteler at itc.it
Sat Apr 9 02:09:21 EDT 2005
I have (hopefully) fixed the problem by adding the missing
file to lib/init and updating the path in gis_set.tcl.
Fixed in 6.0.1-release branch and 6.1-CVS.
So it will appear in both next releases.
Quick solution for you:
For fixing locally, you can grab the file here:
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/lib/init/help.tcl?rev=HEAD&content-type=text/x-tcl
then copy it to
/usr/local/grass6/docs/nviz/help.tcl
as the error message indicates (you will need to create
mkdir -p /usr/local/grass6/docs/nviz
as it won't be existing yet on your machine.
Probably you don't want to miss NVIZ, compiling/installing
it will also cure the problem.
In the CVS versions NVIZ should be again optional. Please
let me know if not.
Best regards
Markus
On Sat, Apr 09, 2005 at 07:41:18AM +0200, Markus Neteler wrote:
> Thanks for indicating the problem.
> We'll modify it to make it independent from NVIZ (as advertized).
> This problem slipped through...
> So as soon as possible they won't be a requirement any more.
> Markus
> On Fri, Apr 08, 2005 at 04:47:01PM +0930, Kingsley Burlinson wrote:
> > Hi Duster
> > This is precisely the problem I encountered and mentioned to the list
> > last week. You MUST have nviz and therefore opengl also, in order for
> > the grass6 gui to work. These items are NOT optional, contrary to the
> > statements in the "requirements" on the grass6 web page.
> > Although the REQUIREMENTS states that you do not have to compile nviz -
> > in fact you DO need to compile Nviz to get the grass6 gui to work .
> > Without nviz, you get this error message. You need to recompile and
> > ensure that you build nviz.
> > And perhaps the reason you did not build nviz was because you do not
> > have opengl on your system. That will prevent nviz from building. (That
> > is the problem I had). You will have to ensure you have opengl (see the
> > link to mesa on the requirements page if you need an opengl) and compile
> > it then rebuild grass to solve this error problem.
> > Opengl and nviz were NOT required in grass 5 - but in grass 6 they are
> > DEFINATE REQUIREMENTS if you require the GUI interface.
> > Check the end of the configure output and make sure it is including
> > nviz. In your grass6 installation directory you should have directory
> > nviz within the docs directory, eg /usr/local/grass6/docs/nviz. Without
> > nviz, there is no nviz directory within docs and the grass6 gui will not
> > work.
> > Kingsley burlinson
> > here is the error I received before I built nviz:
> > >solidus{kgb}621: grass6 -gui
> > >Cleaning up temporary files.....
> > >Starting GRASS ...
> > >Error in startup script: couldn't read file
> > >"/usr/local/grass6/docs/nviz/help.tcl": no such file or directory
> > > while executing
> > >"source $env(GISBASE)/docs/nviz/help.tcl"
> > > (file "/usr/local/grass6/etc/gis_set.tcl" line 36)
> > >Error in Tcl/Tk startup. If necessary, please
> > >report this error to the GRASS developers.
> > Düster Horst wrote:
> > >Hallo
> > >I compiled grass60 from source code today. The compilation process works
> > >well without any error messages.
> > >I try to start grass60 with the command grass60 and the following messages
> > >appears:
> > >WELCOME TO GRASS Version 6.0.0 2005
> > > 1) Have at your side all available GRASS tutorials
> > > 2) When working on your location, the following materials
> > > are extremely useful:
> > > - A topo map of your area
> > > - Current catalog of available computer maps
> > > 3) Check the GRASS webpages for feedback mailinglists and more:
> > > http://grass.itc.it/
> > > http://grass.ibiblio.edu/
> > >Hit RETURN to continue
> > >Starting GRASS ...
> > >"/usr/local/grass-6.0.0/docs/nviz/help.tcl": no such file or dir
> > >ectory
> > > while executing
> > > (file "/usr/local/grass-6.0.0/etc/gis_set.tcl" line 36)
> > >/usr/local/grass-6.0.0/etc/<UNKNOWN>/<UNKNOWN>/.gislock: No such file or
> > >directory
> > >ERROR: /usr/local/grass-6.0.0/etc/lock:
> > >gisusr is currently running GRASS in selected mapset. Concurrent use not
> > >allowed.
> > >What is wrong?? I'll be grateful about any hint.
> > >With best regards
> > >Dr. Horst Düster
> > >GIS-Koordinator /Amtschef Stv.
> > >Kanton Solothurn
> > >Amt für Geoinformation
> > >Abteilung SO!GIS Koordination
> > >Werkhofstr. 65
> > >CH-4509 Solothurn
> > >Tel.: ++41 (0)32 627 25 32
> > >Fax: ++41 (0)32 627 22 14
> > >horst.duester at bd.so.ch
> > >www.sogis.so.ch
> Markus Neteler <neteler itc it> http://mpa.itc.it
> ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18 - 38050 Povo (Trento), Italy
