[GRASSLIST:6472] Re: ps.map output resolution
Thu Apr 14 18:44:20 EDT 2005
> I was searching for, if possible, a way to increase ps.map output
> resolution. Do someone knows if this is possible (and how)?
Do you mean for raster maps? It just uses the region's resolution:
g.region res=
Otherwise everything is scaled at 72dpi, but as PostScript is vector
based, making it 300dpi wouldn't cause any change.
Hamish
