[GRASSLIST:6551] v.in.ascii: Dos text format
Martin du Saire mdusaire at umn.edu
Tue Apr 19 13:54:16 EDT 2005
I ran the following command in Cygwin/Grass60:
v.in.ascii input=vectordata output=myvector
where vectordata was:
230092.881535|2417442.264625|Name
This generated a WARNING: Dos text format found,...
It appears that it correctly generated the vector, but is the "Dos text
format..." going to be a problem a some point?
Thanks.
M
