[GRASSLIST:6553] Re: v.in.ascii: Dos text format
Jaime Carrera
jaicarrerahdez at yahoo.com
Tue Apr 19 15:05:26 EDT 2005
Hi Martin
Just run dos2unix on that file and that will do it.
Jaime
--- Martin du Saire <mdusaire at umn.edu> wrote:
> Hi,
> I ran the following command in Cygwin/Grass60:
> v.in.ascii input=vectordata output=myvector
> where vectordata was:
> 230092.881535|2417442.264625|Name
> This generated a WARNING: Dos text format found,...
> It appears that it correctly generated the vector,
> but is the "Dos text
> format..." going to be a problem a some point?
> Thanks.
> M
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
