[GRASSLIST:6579] Re: Who wants contour lines labeled "300.000000"?
Dylan Beaudette
dylan at iici.no-ip.org
Wed Apr 20 18:19:49 EDT 2005
Dan,
I have experienced similar frustration with contour labeling in GRASS. I think
that part of the reason there aren't yet any robust feature labeling routines
is that GRASS is not (currently) aimed at cartographic output (please correct
me if i am wrong on this Markus, Hamish, and others...).
I have found GMT to be an excellent solution for creating cartographic
products directly based on GRASS rasters. Vector data is a little bit more
complicated, but GMT has some amazing contouring, and contour labeling
routines that make for some very slick looking maps: here is a rather crappy
one, but the contours are nice --
http://169.237.35.250/~dylan/grass_user_group/elev.eps.png
cheers!
for some thoughts on GRASS-GMT operations take a quick look at:
and sooner or later i will finish an article for the GRASS news letter on this
topic...
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
On Wednesday 20 April 2005 02:05 pm, Dan Jacobson wrote:
> Who wants contour lines marked "300.000000"?
> But that's what we're stuck with
> r.contour input=c4 output=c5 step=5
> d.vect display=attr attrcol=level map=c5
> Let's see what else we might try in GRASS 6.0.0beta2 (2005).
> v.label map=c5 column=level labels=c8
> d.paint.labels labels=c8 #BROKEN, so forget it.
> v.out.ascii also broken, so forget examining anything. "It just
> doesn't write any files anymore."
> echo ALTER TABLE c5 ADD COLUMN contour integer|db.execute
> echo UPDATE c5 SET contour = level|db.execute #FAILS,
> who knows how to write this, not me. Docs of course not forthcoming.
> I can't even do "SET contour = 2 + 2", "SET contour = 2" works however.
> And who knows how to remove that column I just added now that I won't
> be using it. Not me. Maybe how to do it is in
> /usr/lib/grass/docs/html/sql.html but I can't tell. Wait:
> echo SELECT cat,level FROM c5|db.select -c|
> perl -pwe 's/(.*)\|(.*)\..*/UPDATE c5 SET contour = $2 \
> WHERE cat = $1;/'|db.execute #WORKS! (Unless you forget the ';': segfault)
> OK, we can finally do
> d.vect c5; d.vect display=attr attrcol=contour map=c5 xref=center \
> bgcolor=white lcolor=black lsize=7
> Quit while I'm ahead? Well can't I have more than one label along a
> contour line, like those maps that Mom used to make?
> Maybe that's what d.paint.labels was for, before it got injured or
> something.
> I know, I'll make a skinny region, the labels are sure to go there.
> d.erase
> g.region w=228000 e=228100
> d.vect c5 #testing: yes, contours appear only in region. Good.
> d.vect display=attr attrcol=contour map=c5 #No, labels still written
> all over the place. BUG.
> I know. I will sit back and let the pros tell me the pro way to put
> more than one contour label on a contour line. Or maybe it's like
> Perl: there's more than one way to do it.
> GRASS: there's less than one way to do it.
> In the article above, Dan Jacobson reflected the frustration he was
> having with GRASS.
