[GRASSLIST:6583] Re: r.out.tiff
    Axel Orth
    axel_orth at gmx.de
    Thu Apr 21 03:42:20 EDT 2005
the result of r.info as follows:
r.info map=freiraum_wil_rec
 | Layer:    freiraum_wil_rec               Date: Mon Apr 18 14:09:39
2005
 | Mapset:   mapset1                        Login of Creator:
xel
kv_wittlich2
 | DataBase:
/home/xel/grass
 | Title:     ( freiraum_wil_rec
 |   Type of Map:  raster              Number of Categories:
255
 |   Data Type:
CELL
 |   Rows:
13212
 |   Columns:
19503
 |   Total Cells:
257673636
 |        Projection: Transverse Mercator (zone
0)
 |            N: 5548802.70517742    S: 5520834.819033   Res:
2.11685484
 |            E: 2583382.86887561    W: 2542094.15180825   Res:
2.11704441
 |   Range of data:    min =  2 max =
255
 |   Data
Source:
freiraum_wil
 |   Data
Description:
 |    generated by
i.rectify
Comments:
 |    Created from:
i.rectify
 |    Transformation order =
1
so its CELL
does that give you any hints about the cause of Signal 11?
cheers
axel
