[GRASSLIST:6590] v.to.rast: Segmentation fault
    Martin du Saire
    mdusaire at umn.edu
    Thu Apr 21 15:49:10 EDT 2005
Running Cygwin/Grass60, I created a vector using v.in.ascii (just a single
point representing a tower where some instrumentation is mounted), and
attempted to v.to.rast input= output= use=val value=1, but this generated a
Segmentation Fault...Core dump.  Presumably, I want to convert the vector
to a raster so I can buffer and patch it with a landcover map.  It seems
like the most recent posts relating to this problem refer to Grass5.0 and
older.
Help.  Please.
Thanks.
Martin
