[GRASSLIST:6603] Re: Creating points on line with calculated value.
Māris Nartišs maris.nartiss at gmail.com
Fri Apr 22 14:12:41 EDT 2005
v.to.points just converts vector line to points andassigns its value
to new points but it doesnt allow to calculate new value for newly
created points.
Currently I assign values to all new points manualy, but there should
be some automatic way to create points at calculated place on line
Maris.
On 4/22/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> how about v.to.points.
> On Friday 22 April 2005 09:27 am, Māris Nartišs wrote:
> > Hi,
> > I have 2 points with values and a line connecting them (i.e. 2 cities
> > and road between them) as two vector files (from 2 shapefiles). I need
> > to create new points on this line in some distance (step) with values
> > smoothly changing form first point value to second point value. New
> > point values have to depend on distance on line from start point.
> > Example:
> > Input: 5 - - - - 10
> > Output:5 6 7 8 9 10
> > As line can be not straight, just creating rast with interpolated
> > values and then uploading rast values to new pionts on line (ie. from
> > v.segment) doesnt solve my problem.
> > Any help welcomed :)
> > I already looked on v.net.* commands, but could not understand a bit
> > from manual. I can understand how to run them, but not what they do :)
> > Maris.
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
