[GRASSLIST:6610] Re: Export vector table to text file?
Jachym Cepicky
jachym.cepicky at centrum.cz
Sat Apr 23 15:25:41 EDT 2005
hi,
On Sat, Apr 23, 2005 at 05:23:06PM +0200, Sander Oom wrote:
> Dear Grass users,
> Probably an obvious question, but I can not find the answer in the help
> files and other references.
> How do I export a vector table directly to a text file from within Grass?
> Thanks in advance for your help,
> Sander.
do you mean database table?
echo "select * from your_vector_file "| db.select -c > text_file.txt
or via ooffice calc, if you want just to edit it and you are not familiar
with SQL
the vectorfile export is made by v.out.ascii, but I don't thing, you need this
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
