[GRASSLIST:6636] Re: Import GRASS-Data from a distant
 Location/Mapset
    Hamish
    hamish_nospam at yahoo.com
    Wed Apr 27 04:54:48 EDT 2005
> I wonder if it is possible to import GRASS-Data into my
> Location/Mapset from a Location/Mapset wich is storted somewhere else
> in the Network? I'm using GRASS for a GIS-Lecture and each user has
> its own Spearfish-Location/Mapsets. This is necessary, because the
> students also should learn to administrate a whole location.
Note maps in the PERMANENT mapset are read only and accessable from all
other mapsets.
To copy a vector map to another computer, just copy over the directory
in $MAPSET/vector/ and possibly the dbf link in $MAPSET/dbf.
scp, 'tar -czf' etc..
To copy a raster map (as you know) you have to copy a lot of files from
a lot of places... one day the raster format will be rewritten & things
will be easier, but in the mean time I have written a couple little
scripts to pack up a raster map for transport to another machine. r.pack
and r.unpack,
see:
 http://grass.itc.it/pipermail/grass5/2004-July/014923.html
It's up to you to make sure the projection settings are the same.
Hamish
