[GRASSLIST:6655] Re: AW: Import GRASS-Data from a distant Location/Mapset
Otto Dassau
dassau at gdf-hannover.de
Thu Apr 28 02:20:03 EDT 2005
Am Donnerstag, 28. April 2005 00:15 schrieb Hamish:
> > I modified your scripts and they run great for my needs.
> > I will attach them to this mail - may be we can put it in the CVS?
> > What I changed:
> > - fixed problem "g.parser not found"
> > - r.unpack didn't remove the path from the *.pack file and tried to
> > import the packed Map with naming it the whole path not only the
> > filename I added a second sed pipe, which removes the path from
> > $GIS_OPT_input
> > Could anyone please try it - I was only able to test it on a
> > Cygwin-machine with GRASS6.1.cvs.
> thanks Marco, I'll merge in the changes and post to the GRASS Add-ons
> section of the WIKI. Maybe Otto wants to add his g.laptop there too?
Yes, I will update for GRASS 6 first and add it then.
> http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
Otto
