[GRASSLIST:6657] Re: map or input
Markus Neteler
neteler at itc.it
Thu Apr 28 03:01:36 EDT 2005
On Wed, Apr 27, 2005 at 04:02:46PM +0100, Glynn Clements wrote:
> Martin du Saire wrote:
> > Is there a practical reason why some commands require "input=" while others
> > require "map="?
> No.
Partially yes.
- If a command comes with a single map parameter, it is map (v.info etc) [1]
- If a command comes with input and output, it is input and output
(r.neighbors etc)
- If a command supports raster and vector and ... the type is specified
(g.region etc)
[1] e.g., r.univar [-qg] input=name is *not* following the logic.
Unfortunately it's still inconsistent. See discussion here:
http://freegis.org/cgi-bin/viewcvs.cgi/grass/documents/parameter_proposal.txt?rev=HEAD&content-type=text/vnd.viewcvs-markup
Markus
