[GRASSLIST:6677] Re: libgrass as TGZ package
Markus Neteler neteler at itc.it
Fri Apr 29 08:05:52 EDT 2005
On Wed, Apr 27, 2005 at 04:58:43PM +0200, Rado Bonk wrote:
> Dear GRASS users,
> Please can you point me to the source code of libgrass? I would like to
> use it within UMN Mapserver environment and can not find it so far.
Hi Rado,
libgrass is available here (GRASS CVS):
 http://freegis.org/cgi-bin/viewcvs.cgi/libgrass/
 there is a "download tarball" link at bottom.
But the recommended method is to use the GDAL/GRASS
plugin. Compilation order:
- GDAL without GRASS support (you may have to actively disable
  it using the appropriate configure switches)
- GRASS 6
- GDAL/GRASS plugin
Configure scripts can be grabbed here:
 http://mpa.itc.it/markus/useful/index.html
 ->  conf_gdal.sh
 ->  conf_grass61_linux.sh
 ->  conf_install_gdal_grass_plugin.sh
Markus
