[GRASSLIST:6678] Re: Overriding awk locales
Jose Gomez-Dans
jgomezdans at gmail.com
Fri Apr 29 08:31:11 EDT 2005
On 4/29/05, Hamish <hamish_nospam at yahoo.com> wrote:
> Please report results of importing 8.3m points with the fixed v.in.ascii
> + DBF driver to the list. It hasn't been tested for something this big
> yet that I know of.
OK, I tried the CVS version
(grass6.1.cvs-i686-pc-linux-gnu-23_04_2005), and importing the data
works up to around 3580000 points. At that point, memory usage is very
high, the mouse cursos is not responsive, and the system freezes with
significant disk activity (swapping). Eventually, the process is
killed by the kernel. I run this version on an AMD Sempron processor
with LInux kernel 2.6.10. The command line I entered was
v.in.ascii -zt input=<input> output=<output> x=1 y=2 z=3
A sample input line:
-2714620.000000| 1477320.000000| 13.290000
Note that I did not test the dbf driver (yet). i will do so shortly
and report back on that.
Many thanks
J
