[GRASSLIST:7809] Re: d.legend not showing up in d.out.png [solved]
Dylan Beaudette dylan at iici.no-ip.org
Sun Aug 7 14:01:45 EDT 2005
Hamish, Michael, and Glynn
Thanks for the pointers. Looks like my misunderstanding was to blame
here! I will jot these great suggestions down in my notebook for next
time.
Dylan
On Aug 6, 2005, at 2:14 PM, Michael Barton wrote:
> I just tried this on Lorenzo Moretti's 16 July 2005 binaries and had no
> problem outputting a legend drawn on a map to a png file. I did a
> pretty
> complex map with a color raster draped over a shaded relief map,
> several
> vector layers, and a legend. I did them all in the GIS manager,
> liberally
> using command layers (including for the legend).
> What I suspect you are doing is drawing a map, then placing a legend
> on it
> using your mouse. This won't work. I've listed the main 'guts' of
> below
> #export display to PNG driver
> dsave=`d.save -a`
> d.mon start=PNG
> eval "$dsave"
> d.mon stop=PNG
> As you can see, it uses the d.save command that writes a history of the
> various d.* commands that have created a map display. It then starts
> the png
> driver and reruns the commands saved with d.save. However, d.save can't
> track your mouse movement. So the script tries to run d.legend but
> gets hung
> up on the legend placement.
> The best way to do this is using coordinates to place the legend. Once
> you
> figure out where you want it, you can cut the command from the output
> window
> of the GUI dialog box, paste it into a command box in the GIS Manager,
> and
> save it with your other map display commands as a workspace file.
> Hope this is helpful.
> Michael
> On 8/5/05 10:15 AM, "Dylan Beaudette" <dylan at iici.no-ip.org> wrote:
>> Greetings,
>> I have noticed in the last couple versions of GRASS 6.0 and 6.1 for
>> linux and
>> macos I have had problems saving the entire contents of a monitor with
>> d.out.png. Specifically, a legend created with d.legend is not
>> included in
>> the output png file... however, everything else is there.
>> does anyone know why this is happening?
>> i have noticed that this has occurred in 3 such instances:
>> 1. GRASS 6.1-CVS for linux-x86
>> 2. GRASS 6.0 debian package for x-86
>> 3. GRASS 6.0 / 6.1-CVS macos X package
>> any ideas?
>> thanks!
> ____________________
> C. Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> PO Box 872402
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
