[GRASSLIST:7826] Re: metadata xml
David Finlayson david.p.finlayson at gmail.com
Mon Aug 8 15:35:30 EDT 2005
If the data is from the US it is more than likely FGDC metadata:
http://www.fgdc.gov/metadata/metadata.html
otherwise it is probably ISO metadata which I think is documented here:
http://www.isotc211.org/
ESRI ArcCatelog has a tool for creating metadata and many datasets are
now taking advantage of that. There are a few stand alone tools for
FGDC metadata but I haven't used them much.
Metadata is a good thing and GRASS should get on this bandwagon.
David
On 8/8/05, ivan marchesini <marchesini at unipg.it> wrote:
> Dear Users,
> I have recently seen that a lot of shp files arrive with a xml metadata
> file...
> do you know if this is a sort of standard??
> is grass able to manage them??
> can qgis manage them???
> do you know where I can find more information about this topic???
> thank you for your answer...
> ivan
> Ivan Marchesini
> Department of Civil and Environmental Engineering
> University of Perugia
> Via G. Duranti 93/a
> 06125
> Perugia (Italy)
> e-mail: marchesini at unipg.it
>         ivan.marchesini at gmail.com
> tel: +39(0)755853760
> fax: +39(0)755853756
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA  98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
