[GRASSLIST:7871] Re: problems importing SRTM30plus files
Carlos Guâno Grohmann carlos.grohmann at gmail.com
Thu Aug 11 13:54:24 EDT 2005
Thanks Ian!
the problem was the byte swapping
looks pretty good now.
Carlos
On 8/11/05, Ian MacMillan <ian_macmillan at umail.ucsb.edu> wrote:
> Carlos, I haven't played with this data specifically, but I think there
> are to possibilities.  First, try byte switching the data from big to
> little endian (or vice versa) when you import it.  If that doesn't
> work, I am guessing that null values are handled as -32767, and 32768.
> Use r.null to replace these values with null, then check out your data.
> G'luck
> -ian
> On Aug 11, 2005, at 10:20 AM, Carlos Guâno Grohmann wrote:
> > Hello all, I'm trying to import some SRTM30plus (30 arcsec) data I get
> > from
> >       http://topex.ucsd.edu/WWW_html/srtm30_plus.html
> > whitch have both land and ocean data,
> > but things are strange. r.in.gdal say the format is no recognised, and
> > r.in.bin can import, but the data range goes from
> > min=-32768
> > max=32767
> > what am I doing wrong?
> > thanks in advance
> >               Carlos Henrique Grohmann - Guano
> >   Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> > Linux User #89721  - carlos dot grohmann at gmail dot com
> What happens if a big asteroid hits Earth? Judging from realistic
> simulations involving a sledge hammer and a common laboratory frog, we
> can assume it will be pretty bad.
>   - Dave Barry
