[GRASSLIST:7928] Re: R Stats and GRASS primer (wanted)
Thomas Adams
Thomas.Adams at noaa.gov
Tue Aug 16 14:44:34 EDT 2005
Roger & Feng,
Ooops. Should have double checked before I posted. Thanks for the
correction, Roger! BTW, I should have my plans to pass through Bergen in
Oct. on my way to Tromso settled by the end of August. I'll let you know.
Regards,
Tom
Roger Bivand wrote:
>On Tue, 16 Aug 2005, Thomas Adams wrote:
>>Feng,
>>Go to CRAN (http://cran.r-project.org/) to the Newsletter section and
>>get the Volume 5/1, May 2005 issue. There is an article on the new
>>GRASS/R interface that's needed with R 2.1 & GRASS 6.x. Hope this helps.
>Please make that: http://grass.itc.it/newsletter/index.php - the article
>is the the GRASS Newsletter volume 3, June 2005, pp. 11-16, and an erratum
>is there too for difficulties installing on a server rather than a
>workstation.
>rast.get() is replaced in the new framework by readFLOATsp() and
>readCELLsp(), so you will have to change your code; in addition, the
>objects returned are different too.
>Roger
>>Tom
>>Feng Tan wrote:
>>>Hi, List,
>>>Thanks for your help. I have successfully installed GRASS6.0/R. It works on
>>>spearfish test dataset. But when I run my own dataset which have worked for
>>>GRASS5.7/R does not work for GRASS6.0/R, it said:"cannot find function
>>>rast.get() ". Please help!!
>>>Thanks!
>>>Feng
>>>On Saturday 23 July 2005 02:04, Markus Neteler wrote:
>>>>Hi Feng,
>>>>I always launched update.packages() before installing the
>>>>sp things. Then a Tcl window pops up where I select a mirror
>>>>site.
>>>>Or: probably you tcl/tk libraries are not installed [properly]?
>>>>Markus
>>>>On Fri, Jul 22, 2005 at 09:23:44AM -0600, Feng Tan wrote:
>>>>>hi, Markus,
>>>>>When I installing the R/GRASS6.0 interface using your instruction , the
>>>>>following error showed:
>>>>>>install.packages(c("sp","rgdal","maptools"), dependencies=TRUE)
>>>>>--- Please select a CRAN mirror for use in this session ---
>>>>>Error in inherits(x, "factor") : Object "res" not found
>>>>>what happened?
>>>>>Thanks,
>>>>>Feng
>>>>>On Thursday 21 July 2005 03:15, Markus Neteler wrote:
>>>>>>[GRASSLIST:7657] Re: R Stats and GRASS primer (wanted)
>>>>>>From:
>>>>>>Markus Neteler
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
