[GRASSLIST:7945] TIN export
Karl Broich b61bro at b61srv5.bauv.unibw-muenchen.de
Wed Aug 17 12:12:04 EDT 2005
Hello,
I want to export a TIN-DEM generated with v.delaunay. Is this possible with
ESRI-shape output using OGR ? (The format generated by v.out.ascii and
v.out.pov is not readable by the software I intend to use for further data
optimization. If not ESRI-format a TIN-output in the following ASCII-format :
- header
- node-element-table
- node-location-table (x,y,z)
would be optimal)
Thanks in advance,
Karl
Dr.-Ing. Karl BROICH			Tel:	+49 / (0) 89 / 6004 2478
Universität der Bundeswehr München	Fax:	+49 / (0) 89 / 6004 3858
Institut für Wasserwesen
Werner-Heisenberg-Weg 39
D 85577 Neubiberg
