[GRASSLIST:7971] Re: grass-6.0.1RC2 compilation
jun liang
liangj at email.unc.edu
Thu Aug 18 13:54:27 EDT 2005
Markus,
Thanks. Your comments are very helpful. I have put a option for the make " make INSTALL=/usr/ucb/install" and it avoided the incorrect reference
for BSD to "/afs/isis/depts/geog/pkg/ipw-1.0/etc/install -c -m 644 ../include/*"
And it bypassed the wildcard problem, but the make did not succeed. I have included the first error below. It seems we are having problem with
"libgrass_datetime".
Jun
cc -I/scratch/grass6/grass-6.0.1RC2/include -I/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/grass -g -KPIC
-DPACKAGE=\""grasslibs"\" -DPACKAGE=\""grasslibs"\" -I/scratch/grass6/grass-6.0.1RC2/include
-I/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/include/grass \
-o OBJ.sparc-sun-solaris2.9/values.o -c values.c
/usr/ccs/bin/ld -G -z text -o /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/lib/libgrass_datetime.6.0.1RC2.so
-L/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/lib OBJ.sparc-sun-solaris2.9/between.o OBJ.sparc-sun-solaris2.9/copy.o
OBJ.sparc-sun-solaris2.9/same.o OBJ.sparc-sun-solaris2.9/diff.o OBJ.sparc-sun-solaris2.9/error.o OBJ.sparc-sun-solaris2.9/format.o
OBJ.sparc-sun-solaris2.9/incr1.o OBJ.sparc-sun-solaris2.9/incr2.o OBJ.sparc-sun-solaris2.9/incr3.o OBJ.sparc-sun-solaris2.9/local.o
OBJ.sparc-sun-solaris2.9/misc.o OBJ.sparc-sun-solaris2.9/change.o OBJ.sparc-sun-solaris2.9/scan.o OBJ.sparc-sun-solaris2.9/sign.o
OBJ.sparc-sun-solaris2.9/type.o OBJ.sparc-sun-solaris2.9/tz1.o OBJ.sparc-sun-solaris2.9/tz2.o OBJ.sparc-sun-solaris2.9/values.o && ln -sf
libgrass_datetime.6.0.1RC2.so /scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/lib/libgrass_datetime.so
Usage: ln [-f] [-s] f1
ln [-f] [-s] f1 f2
ln [-f] [-s] f1 ... fn d1
make[2]: *** [/scratch/grass6/grass-6.0.1RC2/dist.sparc-sun-solaris2.9/lib/libgrass_datetime.6.0.1RC2.so] Error 1
make[2]: Leaving directory `/scratch/grass6/grass-6.0.1RC2/lib/datetime'
Markus Neteler wrote:
> On Mon, Aug 15, 2005 at 03:23:46PM -0400, jun liang wrote:
> > I was trying to compile grass-6.0.1RC2 and had the following error log.
> > The "./configure " worked before that.
> > I guess the problem is due to some libraries' path setting. I am fairly
> > new to grass and any help will be appreciated. Thanks.
> > ubehebe:</scratch/grass6/grass-6.0.1RC2> make
> > mkdir -p /scratch/grass6/grass-6.0.1RC2/bin.sparc-sun-solaris2.9
> > /afs/isis/depts/geog/pkg/ipw-1.0/etc/install -c -m 644 ../include/*.h
> I don't see anything offending in above command.
> > install -- install commands, libraries, etc.
> > Usage: install [-c] [-m mode] [-o owner] [-g group] [-s] file destination
> > make[1]: *** [headers] Error 1
> The other errors are resulting from above problem.
> Does install from sparc-sun-solaris2.9 have problems with wildcards?
> Markus
