[GRASSLIST:8010] Re: r.sim.water or r.sim.sediment
Markus Neteler
neteler at itc.it
Mon Aug 22 00:56:30 EDT 2005
Hi Dylan,
below the answer from Helena. She's not on this list, so please
contact her directly.
Markus
On Fri, Aug 19, 2005 at 10:27:10AM -0400, Helena Mitasova wrote:
> for some reason it did not get into grass6 (maybe I suggested to keep
> it out because it needs more work),
> I can submit it into GRASS61 CVS so that it is in the source, but it is
> still quite experimental
> as some changes in inputs and outputs should be made to make it easier
> to calibrate and we also need to get v.to.rast2 into GRASS6
> (I have an updated version from Jaro) to support pre-defined channels.
> I am actively working on it. The best would be if Dylan contacts me
> directly and let me know what he
> wants to use it for so that I can tell him whether it is worth for him
> to try it out.
> Helena
> Helena Mitasova
> Dept. of Marine, Earth and Atm. Sciences
> 1125 Jordan Hall, NCSU Box 8208,
> Raleigh NC 27695
> http://skagit.meas.ncsu.edu/~helena/
> >On Thu, Aug 18, 2005 at 06:30:10PM -0700, Dylan Beaudette wrote:
> >>Hi,
> >>Does anyone know the status of the commands:
> >>r.sim.water
> >>r.sim.sediment
> >>r.simwe
> >>in either GRASS54 or GRASS6 ?
> >>i have been drooling over the possiblity of using them...
> >>any help would be appreciated!
> >>Dylan Beaudette
> >>Soils and Biogeochemistry Graduate Group
> >>University of California at Davis
> >>530.754.7341
