[GRASSLIST:8050] Re: remove, rename column in DBF
Maciek Sieczka
werchowyna at epf.pl
Wed Aug 24 15:42:35 EDT 2005
Thank you Jachym.
Postgres seems indeed what I need. I'll try to migrate soon. I found your
remarks very usefull.
Maciek
----- Original Message -----
From: "Jachym Cepicky" <jachym.cepicky at centrum.cz>
To: "Maciek Sieczka" <werchowyna at epf.pl>; <grasslist at baylor.edu>
Sent: Wednesday, August 24, 2005 9:24 AM
Subject: Re: [GRASSLIST:8032] remove, rename column in DBF
> hallo,
>> 1. change a column name
> You have to create temporal table without the column, fill it with
> values, delete the original table and rename the temporal table :-/
> for postgres:
> CREATE TABLE temp AS SELECT column1,column2 FROM table;
> DROP TABLE table;
> CREATE TABLE table ( column1 (type), column2 (type));
> INSERT INTO table SELECT * FROM temp;
> DROP TABLE temp;
>> 2. remove a column
> if you are using postgres, there is RENAME key word:
> ALTER TABLE table RENAME COLUMN column to new_column;
> however it seems not to work with DBF driver
>> in DBF datatables, Grass 6.1 CVS.
>> Can somebody please tell if this is indeed impossible?
>> What program do you recommned for manipulating DBFs? GUI preferably but I
>> wouldn't mind a console program.
>> Without remove/rename column functionality I cannot proceed with my
>> current
>> task, and OpenOffice.org's limit od 32767 rows is much too litle for my
>> data.
> I would recommned you to use Postgres for storing atribute data. There
> is lot of good documentation for it
> (http://www.postgresql.org/docs/8.0/static/ddl-alter.html) and it can be
> used realy fast.
> Hope, it helps...
> Jáchym
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/gnupg_public_key/
