[GRASSLIST:8073] Re: v.out.ogr to PostgreSQL
    orkun
    temiz at deprem.gov.tr
    Fri Aug 26 04:56:46 EDT 2005
Stephan Holl wrote:
>Hello orkun,
>On Thu, 25 Aug 2005 15:56:34 +0300 orkun <temiz at deprem.gov.tr> wrote:
>>hello
>>when I try to use /*v.out.ogr as:*//* */
>>v.out.ogr input=jeo6 type=area dsn="PG:host=localhost dbname=bzk
>>user=orkun" olayer=sil format=PostgreSQL
>>it gives:
>>Error: value <PostgreSQL> out of range for parameter <format>
>>       Legal range:
>>ESRI_Shapefile,TIGER,S57,MapInfo_File,DGN,Memory,CSV,GML
>It says that your OGR-Version is lacking Postgresl-Support.
>So you should recompile gdal/ogr with postgresql-support.
>or, if you are on debian
>apt-get install gdal-bin libgdal1 python-gdal
>Best
>	Stephan
thank you
I recompiled both grass61 and gdal.
Now v.out.ogr gives new error.
after entering db.connect driver=pg database=bzk,
user=orkun" olayer=sil7 format=PostgreSQL
ERROR 1: AddGeometryColumn failed for layer sil7, layer creation has failed.
ERROR: Cannot create layer
( is "user=orkun" wrong ?)
what might possible problems be ?
regards
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
