[GRASSLIST:8083] Re: compilation problem
Roger Bivand Roger.Bivand at nhh.no
Fri Aug 26 08:09:41 EDT 2005
On Fri, 26 Aug 2005, Markus Neteler wrote:
> Hi Martin,
> please take out
> --with-blas and --with-lapack
> they are completely useless at the moment. Once day,
> when I have submitted my spectral unmixing tool, it
> will be needed (if you want spectral unmixing then).
Apart from this, the gcc 4 series has gfortran, which is a different
animal from g77, and tests by Prof. Brian Ripley suggest that gfortran may
need a little more time to reach maturity. This is particularly an issue
for Mac OSX users, but I believe that they can step back to their latest
gcc 3.* compile train.
> Markus
> On Thu, Aug 25, 2005 at 12:55:27PM +0200, Martin Landa wrote:
> > Hi all,
> > I cannot compile grass6 any more...
> > CFLAGS="-g -Wall -ansi -D_BSD_SOURCE=1 -D_SVID_SOURCE=1
> > -D_POSIX_SOURCE=1 -D_POSIX_C_SOURCE=199506L" \
> > ./configure --prefix=/usr/local \
> > --with-tcltk-includes=/usr/include/tcl8.3
> > --with-tcltk-libs=/usr/lib/tcl8.3 \
> > --with-postgresql --with-postgres-includes=/usr/include/postgresql
> > --with-postgres-libs=/usr/lib/postgresql \
> > --with-gdal=/usr/local/bin/gdal-config  \
> > --with-proj --with-proj-includes=/usr/local/include
> > --with-proj-libs=/usr/local/lib \
> > --with-blas --with-motif --with-glw --with-nls --with-readline \
> > --with-lapack --with-lapack-libs=/usr/lib/atlas \
> > --with-cxx --enable-large-file \
> > --with-freetype --with-freetype-includes=/usr/include/freetype2
> > I get these errors:
> > Errors in:
> > /usr/src/gis/grass/grass6/lib/gmath
> > /usr/src/gis/grass/grass6/lib/imagery
> > /usr/src/gis/grass/grass6/lib/rst/interp_float
> > /usr/src/gis/grass/grass6/imagery/i.class
> > /usr/src/gis/grass/grass6/imagery/i.cluster
> > /usr/src/gis/grass/grass6/imagery/i.gensig
> > /usr/src/gis/grass/grass6/imagery/i.gensigset
> > /usr/src/gis/grass/grass6/imagery/i.group
> > /usr/src/gis/grass/grass6/imagery/i.his.rgb
> > /usr/src/gis/grass/grass6/imagery/i.maxlik
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/libes
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/menu
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.2image
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.2target
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.camera
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.elev
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.init
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.rectify
> > /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.target
> > /usr/src/gis/grass/grass6/imagery/i.points
> > /usr/src/gis/grass/grass6/imagery/i.rectify
> > /usr/src/gis/grass/grass6/imagery/i.rgb.his
> > I am using Debian GNU/Linux - unstable ...
> > e.g.
> > $ cd /usr/src/gis/grass/grass6/lib/gmath
> > $ make
> > gcc -I/usr/src/gis/grass/grass6/include
> > -I/usr/src/gis/grass/grass6/dist.i686-pc-linux-gnu/include/grass  -g
> > -Wall -ansi -D_BSD_SOURCE=1 -D_SVID_SOURCE=1 -D_POSIX_SOURCE=1
> > -D_POSIX_C_SOURCE=199506L  -Wall -Wconversion -Wno-implicit-int
> > -fPIC    -DPACKAGE=\""grasslibs"\"      -DPACKAGE=\""grasslibs"\"
> > -I/usr/src/gis/grass/grass6/dist.i686-pc-linux-gnu/include/grass \
> > 								 -o
> > 								 OBJ.i686-pc-linux-gnu/del2g.o -c del2g.c
> > In file included from /usr/src/gis/grass/grass6/include/la.h:28,
> >                  from /usr/src/gis/grass/grass6/include/gmath.h:29,
> >                  from del2g.c:22:
> > /usr/include/g2c.h:21: error: syntax error before 'integer'
> > /usr/include/g2c.h:22: error: syntax error before 'uinteger'
> > /usr/include/g2c.h:29: error: syntax error before 'logical'
> > /usr/include/g2c.h:33: error: syntax error before 'longint'
> > /usr/include/g2c.h:34: error: syntax error before 'ulongint'
> > /usr/include/g2c.h:55: error: syntax error before 'flag'
> > /usr/include/g2c.h:56: error: syntax error before 'ftnlen'
> > /usr/include/g2c.h:57: error: syntax error before 'ftnint'
> > /usr/include/g2c.h:62: error: syntax error before 'flag'
> > /usr/include/g2c.h:64: error: syntax error before 'ciend'
> > /usr/include/g2c.h:66: error: syntax error before 'cirec'
> > /usr/include/g2c.h:71: error: syntax error before 'flag'
> > /usr/include/g2c.h:73: error: syntax error before 'iciend'
> > /usr/include/g2c.h:75: error: syntax error before 'icirlen'
> > /usr/include/g2c.h:76: error: syntax error before 'icirnum'
> > /usr/include/g2c.h:81: error: syntax error before 'flag'
> > /usr/include/g2c.h:84: error: syntax error before 'ofnmlen'
> > /usr/include/g2c.h:88: error: syntax error before 'orl'
> > /usr/include/g2c.h:90: error: syntax error before '}' token
> > /usr/include/g2c.h:94: error: syntax error before 'flag'
> > /usr/include/g2c.h:97: error: syntax error before '}' token
> > /usr/include/g2c.h:101: error: syntax error before 'flag'
> > /usr/include/g2c.h:107: error: syntax error before 'flag'
> > /usr/include/g2c.h:110: error: syntax error before 'infilen'
> > /usr/include/g2c.h:111: error: syntax error before '*' token
> > /usr/include/g2c.h:112: error: syntax error before '*' token
> > /usr/include/g2c.h:113: error: syntax error before '*' token
> > /usr/include/g2c.h:114: error: syntax error before '*' token
> > /usr/include/g2c.h:116: error: syntax error before 'innamlen'
> > /usr/include/g2c.h:118: error: syntax error before 'inacclen'
> > /usr/include/g2c.h:120: error: syntax error before 'inseqlen'
> > /usr/include/g2c.h:122: error: syntax error before 'indirlen'
> > /usr/include/g2c.h:124: error: syntax error before 'infmtlen'
> > /usr/include/g2c.h:126: error: syntax error before 'informlen'
> > /usr/include/g2c.h:128: error: syntax error before 'inunflen'
> > /usr/include/g2c.h:129: error: syntax error before '*' token
> > /usr/include/g2c.h:130: error: syntax error before '*' token
> > /usr/include/g2c.h:132: error: syntax error before 'inblanklen'
> > /usr/include/g2c.h:138: error: syntax error before 'integer'
> > /usr/include/g2c.h:144: error: syntax error before '}' token
> > /usr/include/g2c.h:153: error: syntax error before 'ftnlen'
> > /usr/include/g2c.h:155: error: syntax error before '}' token
> > /usr/include/g2c.h:193: error: syntax error before '*' token
> > /usr/include/g2c.h:193: error: 'integer' declared as function
> > returning a function
> > /usr/include/g2c.h:193: error: 'integer' redeclared as different kind
> > of symbol
> > /usr/include/g2c.h:21: error: previous declaration of 'integer' was
> > here
> > /usr/include/g2c.h:198: error: syntax error before '*' token
> > /usr/include/g2c.h:198: error: 'logical' declared as function
> > /usr/include/g2c.h:198: error: 'logical' redeclared as different kind
> > of symbol
> > /usr/include/g2c.h:29: error: previous declaration of 'logical' was
> > here
> > In file included from /usr/src/gis/grass/grass6/include/la.h:46,
> >                  from del2g.c:22:
> > /usr/src/gis/grass/grass6/include/blas.h:8: error: syntax error before
> > 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:9: error: syntax error before
> > 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:10: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:13: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:14: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:15: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:16: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:17: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:18: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:19: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:20: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:21: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:22: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:28: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:29: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:30: error: syntax error
> > before 'ftnlen'
> > /usr/src/gis/grass/grass6/include/blas.h:31: error: syntax error
> > before 'ftnlen'
> > Can anyone help me please? Maybe problem with lapack3-dev and
> > refblas3-dev deb package??
> > Martin
> > Martin Landa <landa at gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
> > CTU Prague, Faculty of Civil Engineering, Czech Republic
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
