[GRASSLIST:8090] Re: AVHRR imagery into GRASS?
Sat Aug 27 04:19:13 EDT 2005
> Anyone had success with importing this data format?
[nit pick: AVHRR is an instrument, not a data format; which format is
your data in?]
Yes, I've done it. Not for a while so I won't give exact instructions,
but I don't remember it being a problem.
Use r.in.gdal:
  http://www.remotesensing.org/gdal/frmt_l1b.html
or failing that you might try r.in.bin.
I seem to recall a connection to the new gdalwarp thin-plate-spline
warping tool for better support for this sort of sequential line
satellite data. (Markus?)
If you figure it out, it would be a useful thing to post to the list so
that others searching the archive can find the instructions.
Hamish
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
