[GRASSLIST:8112] Re:Re:postgresql connection failes
Michele
michele.rocc at libero.it
Mon Aug 29 07:03:31 EDT 2005
> >> Is the server running locally and accepting
> >> connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
> >>What should be done else ?
> >If you reinstall postgres from source you have to manually rebuild the database directory, user, etc..
> >You have to follow carefully this instructions:
> >http://www.postgresql.org/docs/7.4/static/creating-cluster.html
> >http://www.postgresql.org/docs/7.4/static/postmaster-start.html
> >you will also have to create a new database user and remember to use the database administrator user (eg postgres)
> >postgres$ initdb -D /usr/local/pgsql/data
> >to do administration task like starting and stopping the postmaster.
> >Michele.
> thank you
> I can run new postgresql alone using postmaster and psql.
> But grass cannot connect to new postgre, although I have
> recompiled grass with new path of postgresql.
> Ahmet
Ahmet,
If you followed the manpages above and you still have problems, please be more specific about the steps you followed and error messages...
Michele.
____________________________________________________________
Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
Abbonati subito su http://www.libero.it
