[GRASSLIST:8118] RE: v.surf.rast
    Tom Colson
    tom_colson at ncsu.edu
    Mon Aug 29 08:40:53 EDT 2005
I don't have Grass running... But try it using the CLI (command line
interface, which you should know how to use anyway). The GUI, in my personal
opinion, isn't always the ideal method for running tools.
When you do it via the CLI, cut 'n paste that command, but drop
zcolumn=c2cont. Layer=1 should pick up the z col automagically. If that
doesn't work, COPY your layer and rename the c2cont field to z.
Thomas Colson
North Carolina State University
Department of Forestry and Environmental Resources
(919) 673 8023
Calendar:
www4.ncsu.edu/~tpcolson
-----Original Message-----
Sent: Monday, August 29, 2005 8:19 AM
To: Tom Colson
Cc: GRASS mailing list
Subject: Re: [GRASSLIST:8115] v.surf.rast
v.surf.rst input=topopostwet layer=1 zcolumn=c2cont dmax=2.035683
dmin=0.407137 elev=surfpostwet slope=slopepostwet zmult=1.0 tension=40.
smooth=0.1 segmax=40 npmin=200
Authors: original version -  H.Mitasova, L.Mitas, I. Kosinovsky, D.P. Gerdes
See manual pages for reference and publications T3
Percent complete:
Cannot find z column (please verify name) Loading data from attribute table
On 8/29/05, Tom Colson <tom_colson at ncsu.edu> wrote:
> Please copy and paste the command line (From the bottom of the GUI
> window, after you run it, it displays the actuall cli)
> Thomas Colson
> (919) 673 8023
> Calendar:
> From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]
> On Behalf Of M S
> Sent: Monday, August 29, 2005 8:09 AM
> To: GRASS mailing list
> Subject: [GRASSLIST:8115] v.surf.rast
> I have run this in the past with success several times.  This time
> around i'm not sure what i'm doing wrong.
> My input parameters into the GUI are: vector file name (vector
> contours), name of column (i have used the column with integer values
> and floating point), and an output raster of surface, and an output raster
of the slope.
> Everything else is left default.
> when i run the module, i get the following error:
> Percent complete:
> GRASS_INFO_ERROR(24024,1): Cannot find z column (please verify name)
> Loading data from attribute table  . . .
> Any ideas?  I have double/triple/quadruple checked the values in the
> colum for interpolation, and they are there and valid.
