[GRASSLIST:8126] Re:postgresql connection failes
Markus Neteler
neteler at itc.it
Tue Aug 30 02:51:09 EDT 2005
On Mon, Aug 29, 2005 at 02:51:37PM +0300, orkun wrote:
> Michele wrote:
> >>>> Is the server running locally and accepting
> >>>> connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
> >>>>What should be done else ?
> >>>If you reinstall postgres from source you have to manually rebuild the
> >>>database directory, user, etc..
> >>>You have to follow carefully this instructions:
> >>>http://www.postgresql.org/docs/7.4/static/creating-cluster.html
> >>>http://www.postgresql.org/docs/7.4/static/postmaster-start.html
> >>>you will also have to create a new database user and remember to use the
> >>>database administrator user (eg postgres)
> >>>postgres$ initdb -D /usr/local/pgsql/data
> >>>to do administration task like starting and stopping the postmaster.
> >>>Michele.
> >>thank you
> >>I can run new postgresql alone using postmaster and psql.
> >>But grass cannot connect to new postgre, although I have
> >>recompiled grass with new path of postgresql.
> >>Ahmet
> >Ahmet,
> >If you followed the manpages above and you still have problems, please be
> >more specific about the steps you followed and error messages...
> >Michele.
> >____________________________________________________________
> >Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
> >Abbonati subito su http://www.libero.it
> thank you again
> I reviewed the man pages.
> But the problem goes on:
> (before I realized your mail, I had sent a new mail)
> I have no problem connecting to the database without grass:
> postmaster and psql works seems to work properly.
> $ /usr/local/pgsql/bin/postmaster -D /usr/local/pgsql/data -p 5432
There is no -i flag which means that Postgresql doesn't work in
TCP/IP mode. This can be enabled in postgresql.conf
Markus
