[GRASSLIST:8143] Re:postgresql connection failes
orkun
temiz at deprem.gov.tr
Wed Aug 31 03:34:00 EDT 2005
orkun wrote:
> Markus Neteler wrote:
>> On Mon, Aug 29, 2005 at 02:51:37PM +0300, orkun wrote:
>>> Michele wrote:
>>>>>>> Is the server running locally and accepting
>>>>>>> connections on Unix domain socket
>>>>>>> "/var/run/postgresql/.s.PGSQL.5432"?
>>>>>>> What should be done else ?
>>>>>> If you reinstall postgres from source you have to manually
>>>>>> rebuild the database directory, user, etc..
>>>>>> You have to follow carefully this instructions:
>>>>>> http://www.postgresql.org/docs/7.4/static/creating-cluster.html
>>>>>> http://www.postgresql.org/docs/7.4/static/postmaster-start.html
>>>>>> you will also have to create a new database user and remember to
>>>>>> use the database administrator user (eg postgres)
>>>>>> postgres$ initdb -D /usr/local/pgsql/data
>>>>>> to do administration task like starting and stopping the postmaster.
>>>>>> Michele.
>>>>> thank you
>>>>> I can run new postgresql alone using postmaster and psql.
>>>>> But grass cannot connect to new postgre, although I have
>>>>> recompiled grass with new path of postgresql.
>>>>> Ahmet
>>>> Ahmet,
>>>> If you followed the manpages above and you still have problems,
>>>> please be more specific about the steps you followed and error
>>>> messages...
>>>> Michele.
>>>> ____________________________________________________________
>>>> Libero Flat, sempre a 4 Mega a 19,95 euro al mese! Abbonati subito
>>>> su http://www.libero.it
>>> thank you again
>>> I reviewed the man pages.
>>> But the problem goes on:
>>> (before I realized your mail, I had sent a new mail)
>>> I have no problem connecting to the database without grass:
>>> postmaster and psql works seems to work properly.
>>> $ /usr/local/pgsql/bin/postmaster -D /usr/local/pgsql/data -p 5432
>> There is no -i flag which means that Postgresql doesn't work in
>> TCP/IP mode. This can be enabled in postgresql.conf
>> Markus
> thank you markus,
> when I start postmaster with the port which grass is listening postgre
> db from
> grass works on postgredb.
> postgres at landslide:/home/orkun$ /usr/local/pgsql/bin/postmaster -i -D
> /usr/local/pgsql/data/ -k /var/ run/postgresql/
> grass uses this port (/var/ run/postgresql/)
> ** how can I make grass listen postgresql from /tmp/.s.PGSQL.5432 ?
> because at the same time I want to work on same db out of grass
> with psql, but it gives:
> postgres at landslide:/home/orkun$ /usr/local/pgsql/bin/psql bzk
> psql: could not connect to server: No such file or directory
> connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
> kind regards
> Ahmet
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the
> sender's own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
hello
sorry for multiple mails
I found a answer to my last question.
using an soft link, I can listen postgredb at the same time with grass
and psql
is there any better way ?
regards
Ahmet
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
