[GRASSLIST:9270] Re: mapping the output of a population model
Luigi Ponti
lponti at infinito.it
Thu Dec 1 17:33:41 EST 2005
Yes, that was it! Placing the legend on the screen using screen
coordinates worked, as the legend displayed correctly in the .png file.
I am now trying to import a shapefile (with .dbf and .shx dependencies
in the same folder). It contains a Reference EvapoTranspiration Zones
Map for California that I have obtained by contacting California
Irrigation Management Information System (CIMIS)
<http://wwwcimis.water.ca.gov/>. I am using v.in.ogr to import the
shapefile to a latlong location by overriding the projection because I
don't know anything about it.
This is the shell output I get:
[output starts]
GRASS 6.1.cvs (latlong):~ > v.in.ogr
dsn=/home/Administrator/GISBASE/CIMIS/ outp
ut=eto3 layer=eto_utm10_nad27 min_area=0.0001 snap=-1 -o
Over-riding projection check.
Proceeding with import...
Layer: eto_utm10_nad27
WARNING: Area size 0.0e+00, area not imported.
... omissis ... (about 40 lines of the same warning: "WARNING: Area size
0.0e+00, area not imported.")
Building topology ...
344 primitives registered
Building areas: 100%
342 areas built
339 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 341
Number of primitives: 344
Number of points : 0
Number of lines : 0
Number of boundaries: 344
Number of centroids : 0
Number of areas : 342
Number of isles : 339
Number of incorrect boundaries : 4
Number of areas without centroid : 342
WARNING: Cleaning polygons, result is not guaranteed!
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points ... 3372
All points (vertices): 4245
Registered points (unique coordinates): 3372
Points marked for break: 450
Breaks: 512
Remove duplicates:
Duplicates: 133
Break boundaries:
Intersections: 0
Remove duplicates:
Duplicates: 0
Clean boundaries at nodes:
Modifications: 0
Change dangles to lines:
Removed dangles: 0 removed lines: 0
Remove bridges:
Removed bridges: 0 removed lines: 0
353 areas built
216 isles built
Topology was built.
Number of nodes : 451
Number of primitives: 857
Number of lines : 0
Number of boundaries: 857
Number of areas : 353
Number of isles : 216
Number of areas without centroid : 353
931 primitives registered
353 areas built
216 isles built
Topology was built.
Number of nodes : 794
Number of primitives: 931
Number of lines : 0
Number of boundaries: 587
Number of centroids : 344
Number of areas without centroid : 9
392 input polygons
total area: 2.689311e+16 (353 areas)
overlapping area: 0.000000e+00 (0 areas)
area without category: 1.036357e+15 (9 areas)
[output ends]
After importing the vector, it is not possible to display it ("The
bounding box of the map outside current region, nothing displayed.") or
even to g.remove it. However, when I try to open it with QGIS, it
displays with no problem and gives the following "Layer Spatial
Reference System": +proj=longlat +ellps=WGS84 +no_defs.
I also tried to import the vector to a location with "utm10_nad27"-like
projection, as the name of the file would suggest. In this case, GRASS
complains about a coor file which is too big.
If anybody has suggestions, please let me know.
Thanks,
Luigi
Ian MacMillan wrote:
> Luigi, I think that I have seen on this list that you need to place
> your legend without using the mouse. Maybe you could place it on the
> screen using screen coordinates or map coordinates instead?
> G'luck
> -Ian
> On Nov 29, 2005, at 1:11 PM, Luigi Ponti wrote:
>> Thanks Ian,
>> I used it and it worked very well. I also used only the r.mapcalc to
>> clip instead of MASK, so as to clip just one layer and not the entire
>> display.
>> I would like to ask if somebody knows the reason why when saving a
>> display to a .png file with d.out.png, the legend produced via
>> d.legend does not show up in the saved .png image.
>> As a side note, I would like to thank again the mailing: my mapping
>> task is pretty much accomplished.
>> Luigi
