[GRASSLIST:9299] Re: strange behavior from v.to.points : feature or bug?
Radim Blazek
radim.blazek at gmail.com
Mon Dec 5 07:28:07 EST 2005
I would say it is correct. At least what I intended.
dmax is realy maximum limit not exact ditance.
If you need points on exact distance from the beginning
you should use v.segment.
Radim
On 12/4/05, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> Noticed something strange in v.to.points in GRASS61-CVS (current)
> vector 't1' is 1000 meters long
> #this should extract 11 points, each 100 meters apart
> v.to.points -i in=t1 out=t1_points dmax=100
> resulting table:
> | cat | lcat | along |
> | 1 | 1 | 0 |
> | 2 | 1 | 90.9090909090943 |
> | 3 | 1 | 181.818181818189 |
> | 4 | 1 | 272.727272727283 |
> | 5 | 1 | 363.636363636377 |
> | 11 | 1 | 909.090909090943 |
> | 12 | 1 | 1000.00000000004 |
> notice that each point is about 90 meters apart, and there are 12
> points.
> now when i run v.to.points with dmax=110 :
> #this should extract 10 points, each 110 meters apart
> v.to.points -i in=t1 out=t1_points dmax=110
> resulting table:
> | 1 | 1 | 0 |
> | 2 | 1 | 100.000000000004 |
> | 3 | 1 | 200.000000000007 |
> | 10 | 1 | 900.000000000034 |
> | 11 | 1 | 1000.00000000004 |
> the correct and desired result!
> Any ideas on this {feature,bug} ?
> Thanks,
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
