[GRASSLIST:9301] Re: number of rows in a table?
    Kirk R. Wythers
    kwythers at umn.edu
    Mon Dec  5 12:00:37 EST 2005
Thanks for the suggestion. However, the command gives a DBF driver
error:
GRASS 6.1.cvs (arrowhead_utm):~ > echo "select count(*) from
allspecies83" | db.select
DBMI-DBF driver error:
SQL parser error in statement:
select count(*) from allspecies83
Error in db_open_select_cursor()
Am I missing something here?
Kirk
On Dec 4, 2005, at 1:59 PM, Dylan Beaudette wrote:
> On Dec 4, 2005, at 7:24 AM, Kirk Wythers wrote:
>> I need to find the number of rows in a table. I have some vector
>> files that crash qgis, yet grass opens them fine. Looking at the
>> dbf files, I suspect the the issue is the file size (20 - 30 MB).
>> I wanted to check the number of rows and I've been looking through
>> the db commands, unfortunately, so far all I have come across is
>> using using db.describe to get the number of columns. Any
>> suggestions?
>> Thanks,
>> Kirk
> try this
> echo "select count(*) from table" | db.select
> this should return the number of rows in table.
> Cheers,
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
