[GRASSLIST:9319] Re: draw line from (x,y) point and bearing
[solved: new module]
Michael Barton
michael.barton at asu.edu
Mon Dec 5 21:38:50 EST 2005
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Tue, 06 Dec 2005 13:27:33 +1300
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <werchowyna at epf.pl>, <dylan.beaudette at gmail.com>, <GRASSLIST at baylor.edu>,
> <neteler at itc.it>
> Subject: Re: [GRASSLIST:9305] Re: draw line from (x,y) point and bearing
>> Maybe a better idea is to make this function a flag of r.transect. Or
>> even better, merge r.transect and r.profile, and make the vector
>> output line a flag. What do you think?
> fyi, r.transect is already just a simple frontend to r.profile.
Right. This is why I suggested that they might be merged.
> You can use the -g flag to get geographic coordinates (which can be fed
> into v.in.ascii, either as points or form a line from the verticies*),
> and the -c flag to get a GRASSRGB column for filling color (or other
> thematic use).
> [*] see v.in.garmin script
> Make the segment distance longer than your line length, and you get end
> point coordinates from a dist,azimuth. (?)
Wouldn't it make sense to put all this together into a module rather than
having several partly overlapping ones? Seems it would be more functional in
that case too. I don't know how much work it would be though.
Michael
> Hamish
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
