[GRASSLIST:9338] Re: Extracting and sum values in a tab
Luca Casagrande
luca.casagrande at gmail.com
Tue Dec 6 10:43:11 EST 2005
Thx for your answer Ivan....
Right now I have got the layer to work with, but i still don't know how
calculate the area of a buffer i created.
I have created a buffer around an area (100 m of distance) inside the
regoion,but i don't know how calculate the area...
Thx
Luca
>Alle 12:54, martedì 06 dicembre 2005, ivan marchesini ha scritto:
> You should use v.reclass for obtaining a map (PIPPO.map) where each area
> feaure has a cat described by the region value (before this you should
> give an integer code to the region column, for example A=1 B=2, and so
> on.., or creating a new column named for example region.int )
> later yuou can use the sql command
> create table PIPPO as select REGION.INT, sum( TOTAL_POPULATION) from
> YOUR_TABLE group by REGION.INT
> for creating a new table called pippo where you have the region code
> (1,2,3,....) and the sum of the area values for each code...
> later, using v.db.connect, you can connect the PIPPO.map to the PIPPO
> table using the region code as a key...
> hope this help....
> Ivan
> Il giorno lun, 05-12-2005 alle 19:43 +0000, Luca Casagrande ha scritto:
> > Hi guys
> > I have got an area vector layer that describes the extension of different
> > cities and also the region in where them are; the table associated is
> > something like this:
> > REGION CITY EXTENSION
> > A test1 100000
> > A test2 5000
> > B ........ 20000
> > C ........ 300000
> > I'd like to create a surface layer that describes the extensionof each
> > region and with a tab like this one:
> > REGION TOTAL POPULATION
> > A Sum of all
> > B Sum of all
> > C Sum of all
> > Can this be done?
> > Thx
> > Luca
