[GRASSLIST:9397] Re: Issue with v.in.ogr..
    Radim Blazek
    radim.blazek at gmail.com
    Fri Dec  9 12:06:40 EST 2005
On 12/9/05, Luca Casagrande <luca.casagrande at gmail.com> wrote:
> Hi guys!
> I am trying to import an ESRI shp file using v.in.ogr in GRASS 6.0.1; as you
> can see here: http://www.geocities.com/gubbiosupp/schermorast2.jpg a same
> region on my map is splitted in 2 parts, but in the attribute tables i got
> only 1 row for it.
> When I import the map, grass create 2 different regions and 2 differents row
> on the tab, both with the same information...
In GRASS the areas should be linked to 1 row.
In QGIS the to areas are represented as 2 features which
is not correct but I have not decide yet when features linked to
single row should be represented as 'multi'. In GRASS
can be thousands of geometry elements linked to one row,
but converted to single 'multi' feature would become huge
and probably crashed.
Any ideas when to represent them as multi and when as single?
Radim
> Am I missing something?
> Thx
> Luca
