[GRASSLIST:9402] Re: AW: Problem installing GDAL
Glynn Clements
glynn at gclements.plus.com
Fri Dec 9 16:09:12 EST 2005
Maik Trömel wrote:
> >> --with-grass='/.../grass-6.0.1/lib/'
> > try --with-grass=/usr/local/grass-6.0.1/
> Same problem. Is it possible that I've got the wrong version of one
> package?
Look in the config.log file which GDAL's configure script creates. It
should contain the exact error message indicating why that test
failed.
