[GRASSLIST:9412] Re: Reading and converting VMAP0
    Nick Cahill
    ndcahill at facstaff.wisc.edu
    Sat Dec 10 15:24:53 EST 2005
Just in case anyone else is in the same boat, I installed William
Kyngesburye's gis libraries for Mac OSX, and these were able to
convert vmap0 files to shapefiles successfully. I don't know why this
didn't work with the library files installed by Lorenzo Moretti's
installation of GRASS - but in any event, I'm happy.
It would be a big service for someone to convert all that data to
shapefiles and make it available on the web. Is there an advantage to
keeping it in the original VMAP0 format?
Nick Cahill
On Dec 10, 2005, at 12:31 AM, William Kyngesburye wrote:
> Unless OGDI is hacked to behave like the examples (my GIS Libs
> package is, but Lorenzo uses his own build), that 'vrf' part must
> be spelled out so it can find the library.  Normally the OGDI
> format code looks for the standard unix .so extension for
> libraries.  Try using libvrf.dylib instead of vrf.  If that doesn't
> work, it needs a location to find the library: set
> DYLD_LIBRARY_PATH in your shell to wherever Lorenzo has his
> libraries (I think it's /usr/local/grasslib/lib).  For the tcsh shell:
> setenv DYLD_LIBRARY_PATH /usr/local/grasslib/lib
> On Dec 9, 2005, at 3:11 PM, Nick Cahill wrote:
>> I am trying to import vmap0 files into GRASS using the very useful
>> article by Marks Neteler in GRASS Newsletter 3, with Lorenzo
>> Moretti's binaries on Mac OSX (Grass 6.1cvs of Nov. 22). I removed
>> all the trailing periods, lowercased the filenames, but I can't
>> get anything to read the files. When I run ogrinfo
>> [Nick:local/grasslib/bin] nick% ./ogrinfo -ro -summary gltp:/vrf/
>> Users/nick/v0eur/vmaplv0/eurnasia 'polbnda at bnd(*)_area'
>> FAILURE:
>> Unable to open datasource `gltp:/vrf/Users/nick/v0eur/vmaplv0/
>> eurnasia' with the following drivers.
>>   -> ESRI Shapefile
>>   -> UK .NTF
>>   -> SDTS
>>   -> TIGER
>>   -> S57
>>   -> MapInfo File
>>   -> DGN
>>   -> VRT
>>   -> AVCBin
>>   -> REC
>>   -> Memory
>>   -> CSV
>>   -> GML
>>   -> ODBC
>>   -> OGDI
>>   -> PostgreSQL
>>   -> MySQL
>> Nothing I've tried seems to work. Has anybody had success with
>> this? Is it possible that there is something wrong with the
>> binaries? ogrinfo works fine with shapefiles, but doesn't seem to
>> like VPFs.
>> Thanks for any help you can offer,
>> Nick Cahill
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
