[GRASSLIST:9417] Re: d.vect gives error
Sun Dec 11 01:40:10 EST 2005
> I found neccessary command to generate contours from DEM.
> But after generating contours using r.contours. d.vect gives:
> GRASS_INFO_WARNING(10978,1): coor files of vector 'elv2_cont3 at orkun'
> is larger than it should be (14 bytes excess).
> what can I do ?
try v.build and/or v.clean to fix any errors in vector maps.
Hamish
