[GRASSLIST:9425] DBMI errors with MySQL tables
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Dec 12 15:30:20 EST 2005
Greetings,
Lately I have been having a lot of DBMI-related errors when working with
GRASS{6,6.1-CVS} vectors that have a MySQL table attached to them.
For example, I have a table that looks like this in MySQL:
gg_bulk_density_points;
| Field | Type | Null | Key | Default | Extra |
| cat | int(11) | YES | | NULL | |
| easting | int(11) | YES | | NULL | |
| northing | int(11) | YES | | NULL | |
| id | varchar(10) | YES | | NULL | |
| pedon_id | varchar(20) | YES | | NULL | |
| the_date | varchar(12) | YES | | NULL | |
| the_time | varchar(6) | YES | | NULL | |
| db_ring_hz1 | float | YES | | NULL | |
| db_ring_hz2 | float | YES | | NULL | |
| db_ring_hz3 | float | YES | | NULL | |
| db_ring_hz4 | float | YES | | NULL | |
| clay_capacity | float | YES | | NULL | |
| dominant_cover | varchar(20) | YES | | NULL | |
I have connected this table to a vector in GRASS{6,6.1-CVS} like this:
v.db.connect -o map=gg_bulk_density_points driver=mysql
table=gg_bulk_density_points database="host=localhost,dbname=test" key=cat
Running db.columns returns:
db.columns table=gg_bulk_density_points;
cat
easting
northing
id
pedon_id
the_date
the_time
db_ring_hz1
db_ring_hz2
db_ring_hz3
db_ring_hz4
clay_capacity
dominant_cover
Running db.select on this table gives:
echo "select * from gg_bulk_density_points" | db.select
dbmi: Protocol error
Running db.select on any other vector in this location, with a MySQL table
attached to it works fine...
Also: Trying to add this trouble vector+table in QGIS causes QGIS to die with
"DBMI error"
Any Ideas, as this is really starting to drive me nuts!
Could it possibly be a column type issue?
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
