[GRASSLIST:9426] Re: Problem installing gdal-grass-1.3.1
    Hernán De Angelis
    hernan.deangelis at glocalnet.net
    Mon Dec 12 15:33:56 EST 2005
Maik,
Are your GRASS and GDAL in standard directories? If not, if you only did
./configure
without specifying
--with-grass=/your/path/to/grass/
and
--with-gdal=/your/path/to/gdal/bin/gdal-config
it will never work. In that case you might also need to make the libraries
accesible in /etc/ld.so.conf (and run "ldconfig" as root after that)
Hope this helps
Hernán
El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
> Hello GRASS-Users,
> installing GRASS-6.0.1 from tar.gz I got a problem with gdal-grass-1.3.1.
> I run:
> ./configure  -> no problem
> make -> no problem
> make install (as root):
> > install -d /usr/lib/gdalplugins
> > cp gdal_GRASS.so /usr/lib/gdalplugins
> > cp: cannot stat `gdal_GRASS.so': No such file or directory
> > make: *** [install] Error 1
> Anybody an idea what the problem could be?
> Thanks for help!
> Maik
Hernán De Angelis
