> According to the manual v.in.ascii uses the | separator. Is it worth > to manually put the file in that format or do you think is better to > convert it in a database to connect with a specific command? You can use the v.in.ascii fs= option to set the separator to whatever you like. e.g. "fs=," or "fs=tab" Hamish
