[GRASSLIST:9433] Re: Problem installing gdal-grass-1.3.1
Maik Trömel
maik.troemel at maitro.net
Tue Dec 13 03:13:00 EST 2005
Thanks for your support,
Hamish wrote:
>>installing GRASS-6.0.1 from tar.gz I got a problem with
>>gdal-grass-1.3.1.
>To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug in
>1.3.1 release)
>http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
I tried it: Same problem.
>Hamish
Hernán De Angelis wrote:
>Maik,
>Are your GRASS and GDAL in standard directories? If not, if you only did
>./configure
>without specifying
>--with-grass=/your/path/to/grass/
>and
>--with-gdal=/your/path/to/gdal/bin/gdal-config
I ran it this way. I think thats not the problem.
>it will never work. In that case you might also need to make the libraries
>accesible in /etc/ld.so.conf (and run "ldconfig" as root after that)
I have updated /etc/ld.so.conf and run ldconfig. It has no influence on
the problem.
>Hope this helps
>Hernán
>El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
>>Hello GRASS-Users,
>>installing GRASS-6.0.1 from tar.gz I got a problem with gdal-grass-1.3.1.
>>I run:
>>./configure -> no problem
>>make -> no problem
>>make install (as root):
>>>install -d /usr/lib/gdalplugins
>>>cp gdal_GRASS.so /usr/lib/gdalplugins
>>>cp: cannot stat `gdal_GRASS.so': No such file or directory
>>>make: *** [install] Error 1
>>Anybody an idea what the problem could be?
>>Thanks for help!
>>Maik
