[GRASSLIST:9472] Re: Problem installing gdal-grass-1.3.1
Maik Trömel
maik.troemel at maitro.net
Wed Dec 14 04:10:27 EST 2005
Its still the same problem. But i'm running another Version (6.0.1).
There is no "grass-6.x.x.cvs in /usr/local/grass-6.0.1/. But I don't
think that this is the problem.
@Luca: It is doing good, not to be alone ;-P
Please post it, when you get it on your own.
Luca Casagrande wrote:
> Alle 17:34, martedì 13 dicembre 2005, Hernán De Angelis ha scritto:
>> Maik,
>> I did my installation last weekend. I did the following configure:
>> ./configure --prefix=/usr/local/gdal-grass-1.3.1
>> --with-gdal=/usr/local/gdal/bin/gdal-config
>> --with-grass=/usr/local/grass-6.1.0/grass-6.1.cvs
>> and everything went smoothly. In my box, these two files were
>> installed in:
>> /usr/local/gdal-1.3.1/lib/gdalplugins
>> I am not an expert but I guess that in your case something was left
>> from a
>> previous failed attempt to install. I think it would be a good idea
>> to do a
>> "make distclean" on the source directory of gdal-grass and start a new
>> build.
>> Good luck!
>> Hernán
>> El Martes 13 Diciembre 2005 15.49, Maik Trömel escribió:
>>> I had a look on the "Makefile"
>>> Line 49:
>>> GLIBNAME = gdal_GRASS.so
>>> OLIBNAME = ogr_GRASS.so
>>> default: $(GLIBNAME) $(OLIBNAME)
>>> install: default
>>> install -d $(AUTOLOAD_DIR)
>>> cp $(GLIBNAME) $(AUTOLOAD_DIR)
>>> cp $(OLIBNAME) $(AUTOLOAD_DIR)
>>> The error occures when trying to copy gdal_GRASS.so to $(AUTOLOAD_DIR).
>>> I can't find gdal_GRASS.so . But why isn't it where it should be. Where
>>> should I find this file? Is it from gdal_grass-package or from another
>>> package? Where is it initialised?
>>> Anybody an idea?
>>> Greetings
>>> Maik
>>> Maik Trömel wrote:
>>>> Thanks for your support,
>>>> Line 49:
>>>> install: default
>>>> $(AUTOLOAD_DIR).
>>>> Where should I find this file? Is it from gdal_grass-package or from
>>>> another package? Where is it initialised?
>>>> Anybody an idea?
>>>> Greetings
>>>> Maik
>>>>> Hamish wrote:
>>>>>>> installing GRASS-6.0.1 from tar.gz I got a problem with
>>>>>>> gdal-grass-1.3.1.
>>>>>> To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug
>>>>>> in 1.3.1 release)
>>>>>> http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
>>>>> I tried it: Same problem.
>>>>>> Hamish
>>>>> Hernán De Angelis wrote:
>>>>>> Maik,
>>>>>> Are your GRASS and GDAL in standard directories? If not, if you only
>>>>>> did
>>>>>> ./configure
>>>>>> without specifying
>>>>>> --with-grass=/your/path/to/grass/
>>>>>> and
>>>>>> --with-gdal=/your/path/to/gdal/bin/gdal-config
>>>>> I ran it this way. I think thats not the problem.
>>>>>> it will never work. In that case you might also need to make the
>>>>>> libraries accesible in /etc/ld.so.conf (and run "ldconfig" as root
>>>>>> after that)
>>>>> I have updated /etc/ld.so.conf and run ldconfig. It has no influence
>>>>> on the problem.
>>>>>> Hope this helps
>>>>>> Hernán
>>>>>> El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
>>>>>>> Hello GRASS-Users,
>>>>>>> gdal-grass-1.3.1.
>>>>>>> I run:
>>>>>>> ./configure -> no problem
>>>>>>> make -> no problem
>>>>>>> make install (as root):
>>>>>>>> install -d /usr/lib/gdalplugins
>>>>>>>> cp gdal_GRASS.so /usr/lib/gdalplugins
>>>>>>>> cp: cannot stat `gdal_GRASS.so': No such file or directory
>>>>>>>> make: *** [install] Error 1
>>>>>>> Anybody an idea what the problem could be?
>>>>>>> Thanks for help!
>>>>>>> Maik
>>>>>> gdal-grass-1.3.1.
>>>>> bug in
>>>>> 1.3.1 release)
>>>>> Hamish
>>>>> Maik,
>>>>> did ./configure
>>>>> without specifying
>>>>> and
>>>>> after that)
>>>> on the problem.
>>>>> Hope this helps
>>>>> Hernán
>>>>>> Hello GRASS-Users,
>>>>>> gdal-grass-1.3.1.
>>>>>> I run:
>>>>>> make -> no problem
>>>>>> Thanks for help!
>>>>>> Maik
> I tryed with your same configure and after a DEEP clean, but the error
> it's the same...
> Thx
> Luca
